See my previous post here for details and video of car idling poorly La-Z-Link - Poor Idle Since this post, I've replaced both oxygen sensors and tested / reset TPS. The issue still persists, so I decided to get a consult hookup and see if I can figure whats going on. It's my first time using Conzult, I thought I'd get some expert eyes on the readings. La-Z-Link - Conzult Readings
The standout that I see is the duty cycle on the IACV-AAC is significantly higher than it should be (70-ish%). And the timing appears to be off a bit at 22-24BTDC. (Need to verify with a light) I was able to get a somewhat normal idle by backing out the idle adjustment screw with a still elevated duty cycle. Running through the procedure to "set" the idle correctly by disconnecting the AAC running the adjustment screw in and re-connecting the AAC did not allow me to have a decent idle and a low duty cycle on the IACV/AAC, and connecting the AAC afterwards had no impact on raising the idle as expected. Does this point to a failed AAC? Anything else seem out of whack? Anything else I should check?
